LS6 Spring Vortec Head Install
Old May 25, 2014 | 08:53 AM
LB87FORMULA's Avatar
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
Decided to install new LS6 valve springs in my machined vortec heads. Heads were bought from Pace Performance, which were good for .550 lift, but the springs were old GM dual 330585. Used 787-16 Comp Cam retainers.
Measured Installed LS6 Spring Height: 1.73"
Closed Seat Pressure: 90lbs + (1.8-1.73)inch x 375lbs/inch = 116lbs
Coil Bind Lift: 1.73" - 1.085" = .645"
Retainer to Seal distance: .83
Max cam lift: .645" - .05 margin = .595"
I am installing the Lunati 20080130 Cam, LT4 Hot Cam clone, with .503 and 1.6 Pro Magnum rockers, giving .536 max lift.
Looks like I should have plenty of clearance. Did I miss anything? Is the installed height of the springs ok?
Attached Thumbnails LS6 Spring Vortec Head Install-ls6-spring-vortec-install.jpg
Old May 25, 2014 | 12:07 PM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: LS6 Spring Vortec Head Install
I haven't had my coffee yet so I'm not looking at the math.
Make sure you measure everything on all 16 valves. Also make sure the pushrod holes in the head have clearance.
Here goes a visual install that might help you out.
http://www.pacificp.com/forum/viewto...r=asc&start=20
Old May 25, 2014 | 12:11 PM
Damon's Avatar
You're good to go.
Old May 25, 2014 | 12:31 PM
Thanks for the feedback. That link also had some good pictures.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
sailtexas186548
Aug 26, 2015 03:32 PM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
