Two Fuel Pumps
Two Fuel Pumps
I have an 87 Trans Am that has two fuel pumps. One electric in tank and a mechanical on the block. This is the carb version 305. Why did they use two pumps? The electric died and I'm wondering if you can get away with just the mechanical.
Thanks!
Thanks!
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Two Fuel Pumps
The last car that had your setup, I eliminated the mechanical pump, installed a TPI pump and sending unit in the tank, and used a bypass style return regulator on the firewall to limit the pressure down to 5 psi.
Car: 1983 Z28
Engine: 385 Fastburn
Re: Two Fuel Pumps
You'll have vapor locking problems. The electrical pump was there to keep the line primed going to the mechanical pump, if that makes sense.
Car: 1983 G20 Chevy
Transmission: 4L60
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Two Fuel Pumps
The in-tank pump is a booster pump used to help prevent vapor locking.
This is my set up. Ditched the mechanical and in-tank pusher pump because my pusher pump was D.E.D..dead. Thread
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
