EGR switch
Old Jun 18, 2014 | 11:51 PM
eldy's Avatar
Car: 89 formula TPI
Engine: 5.0 l
Transmission: 5 spd
Axle/Gears: 3:45
EGR switch
Not sure where to post this ,but the oft referenced discontinued GM Egr switch 14087416 is now available as a reproduction part for the 1985 Corvette. Althought there seems to be a little confusion on the p/n verus the wire lenght. Corvettes used this part with 17 inch wire lenght in 1985 and 12 inch (14087415) for 1986thru 1989.
Anywho my wife's 1989 FB formula 305TPI, 5 spd started the start and die routine, which usually means a stuck open EGR valve. So I decided to replace the EGR valve, MAT sensor and the EGR switch all at the same time.
I found the repo EGR switch at Davies Corvette in New Port Richey,Fla. Their part number is 333025 and Micheal there opened the box and assured me that the part had a 17 inch wire and OEM connector. It costs $60 but the shiiping was reasonable and quick to Ohio.
I ordered one and the box is marked 1985 corvette egr switch on the top but the end flap reads 14087415, style 2. But the correct part was in the box and worked fine to fix the intermittent problem on the original,which had the conection on the egr switch broken but sometimes working.
Hope this helps some with the EGR switch problem.
Davies Corvette is 800-236-2383 or www.corvetteparts.com ask for Micheal, a real helpful fellow . I would attach pic's but I don't know how.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
FormulasOnly
Sep 10, 2015 09:07 PM
rjcme
Sep 5, 2015 01:23 PM
luvofjah
Sep 3, 2015 07:08 PM
