what spark plug and heat range for new engine?
Old Jun 27, 2014 | 09:28 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Recently finished building a 383 and need some advice on what plug to run
I'm running about 10:5:1 compression with a set of PBM strike force heads, with a factory ignition other then a msd coil and plug wires.
I usually prefer ngk and figure around a 4-5 for heat but what about the rest of the part number?>
Old Jun 27, 2014 | 10:40 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: what spark plug and heat range for new engine?
You want the coldest plug possible that doesn't foul up. Best plug temperature depends on a lot of factors. The only way to know which temperature range you need for your particular selection of components and settings is to try a set and read the heat line on the ground strap. Too hot a plug and the tip melts. Too cold a plug and it fouls up.
Spark plugs are cheap. For a daily driver type engine, start with some ACdelco R44TS. If they foul up, go to a R45TS
With the NGK race plugs in my engine, NGK's temperature numbers go up with a colder plug. ACdelco's go down with colder plugs.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
