fuel injector replacement
Old Jul 4, 2014 | 07:44 AM
harleyellett's Avatar
do I have to take the complete fuel rail assembly and all that other crap off just to replace a fuel injector? I have an 89 iroc 5.0 tpi
Old Jul 4, 2014 | 09:09 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: fuel injector replacement
There isn't much difference between replacing one, and being able to replace them all (or all 4 on that side).
If you can reach and unbolt the 4x 10mm bolts holding the fuel rail down, then maybe.
When I last changed injectors, I removed the plenum and the passenger side runner... to loosen/remove the 4 fuel rail bolts to get enough clearance to remove the injectors. Whether you disconnect the TB, or remove it from the plenum is your choice.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
