Why does coolant run through the HVAC?
Old Jul 13, 2014 | 07:15 PM
Renier's Avatar
Car: '89 Camaro RS
Well, I was wondering why coolant runs through the HVAC? I just managed to get my HVAC operational again by replacing the fuse, but my coolant supply from the engine to the HVAC is blocked off, the coolant is directly reintroduced into the engine instead with a single hose running to and from the engine instead of through the HVAC. Am I at risk of breaking something in the HVAC or will my HVAC work less properly due to this?
Thanks in advance, guys!
Old Jul 13, 2014 | 07:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Why does coolant run through the HVAC?
Lol the hot coolant is how the hvac generates heat for the fan to blow. Thats why in the winter, you have to wait til car heats up before hot air is blown
Old Jul 13, 2014 | 07:54 PM
KILLemALL's Avatar
Car: 77 Y82
Engine: W72
Transmission: Super T-10
You won't hurt anything if your heater core is bypassed,you just won't have heat to the cockpit
Old Jul 13, 2014 | 07:55 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
What Orr said is correct. This is how the heater works. It is likely that someone bypassed the heater core because it was leaking and they didn't want to replace it. If you decide you want or need heat in your vehicle, be ready to check for leaks as soon as you hook the hoses up to the heater core. It is always a possibility that the PO (previous owner) disconnected the heater core for some other reason, but on a street car I can't think of a good reason to do so.
Old Jul 14, 2014 | 03:28 AM
Renier's Avatar
Car: '89 Camaro RS
Alright, makes sense. Thanks a bunch, guys!
Old Jul 14, 2014 | 12:20 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
be advised, that if your heater core IS leaking. you cant buy a real deal core anymore. all the parts houses only sell aluminum or worse PLASTIC!! you can remove your original one and have it repaired at your local radiator shop.
Old Jul 16, 2014 | 05:54 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
also be advised that a leaking core may allow coolant onto//into your pcm
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
TheExaminer
Aug 26, 2015 04:59 PM
