Timing MArks, Peaks 4 or 2deg apart?
Old Jul 28, 2014 | 09:25 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I have 88 305 TPI. Stock timing it was a little to the right of the first front facing peak after the big rear facing peak, being 0degrees. So the first peak to the right of 0. My stock timing was a pas that in the valley between 1-2 peaks.
The guide here states the first peak is 4dege advanced and the 2nd = 6 degrees. I advanced mine the 2nd on and changed the code.I set the code originally to 5 degrees since it was sitting in the valley of 1-2.
Now other searched state it is 4 and 8 degrees for the peaks and the valley being 6. This would make more sense since the car was stock and untouched when I found it. can not imagine some one retarded 1 degree.
So on the 2nd peak form the 0 mark what are my degrees? I want to update my code.
Old Jul 28, 2014 | 08:12 PM
Damon's Avatar
Re: Timing MArks, Peaks 4 or 2deg apart?
Correct. Each point is 4*, each "valley" is the 2* in between each point, except for the "big V' which is 0* (TDC).
So, second point CCW (to the left) of the big V is 8* BTDC.
Old Jul 28, 2014 | 08:26 PM
jjcuff1's Avatar
Thanks!!
So the sticky tech article on here is wrong it reads it as 4 and 6
So I have been running 6 in code but 8 on dizzy I need to match it so not off thanks
midge54
Dec 27, 2019 04:14 PM
ezobens
Aug 19, 2015 10:29 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
