speedo questions
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
speedo questions
Hey guys been a long time since I've been on anyways got a few questions. First off the other day I was driving my car and I took off kinda hard and my speedo stopped working I was wondering what could have caused this.. when I had my new gears put in I also had that the drive gears in rtf he tail shaft of the tranny replaced as well to adjust the speedo. Cold one of these broke? Also related to this I plan on changing my stock gauges out to auto meter ones. The question I have here is that I have installed a 383 stroker and switched to a carb should I use a mechanical speedo or an electric one?
Engine: 383 stroker
Re: speedo questions
well been a while since I have been on I haven't really driving my car much been busy with life still having problems with speedo any advice?
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
The ecm in those years cars buffs the signal from the vss. I'd get under the car and check to see if there are wires that have melted or been ripped off. It'll be on the driver's side of trans. The vss could possibly be bad. If all else fails you can just get a speedo interface and hook it all back up bypassing the ecm.
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
