vortec harmonic balancer
Old Aug 14, 2014 | 03:33 PM
kenjames23's Avatar
Car: 1982 Z28
Engine: 350 880 block
can i use my harmonic balancer from my 1986 305 z28 engine or my harmonic balancer from my 1988 z28 engine
Old Aug 14, 2014 | 03:42 PM
Damon's Avatar
Re: vortec harmonic balancer
A factory Vortec motor has a crank position sensor ring in front of the timing chain gear on the crank. It's about 1/8" thick, so GM shortened the hub on the balancer by the same amount. If you put on an earlier balancer the face of it will be out about 1/8" too far, and your pulleys won't line up properly.
If you remove that crank position sensor ring (i.e. you are not running a factory Vortec EFI system), then you can use an earlier pre-Vortec balancer.
Old Aug 14, 2014 | 03:49 PM
kenjames23's Avatar
Car: 1982 Z28
thanks
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Magman
Sep 13, 2015 12:14 AM
