Guess my HP - Going to dyno this Saturday
Old Aug 19, 2014 | 11:28 AM
CamaroX84's Avatar
I'm heading to a chassis dyno this Saturday to get my 84 Camaro tuned by an expert FAST XFI tuner. I just thought it would be fun to make a guess as far as horsepower is concerned. I will post the results afterwards. The setup is as follows:
- 355 ci SBC
- 10.5:1 compression
- Air Flow Research 195cc heads
- Comp hydraulic roller cam (230/236 dur @ .050, .510/.520 lift)
- 1.6:1 roller rockers
- FAST multiport EFI system with 39 lb/hr injectors, 4 barrel air-only throttle body, fully programmable XFI 2.0 ECU
- MSD 6AL ignition box
- Edelbrock Victor E EFI manifold, port matched to Fel-Pro 1205 gaskets
- Hooker 1-5/8" headers to a 3" single exhaust, no cats
- I have an exhaust cut out just after the down pipes converge, and will try and run it with the cut out both open and closed.
- 700R4 Pro-Built trans
- Running 93 octane pump gas
Thanks!
Old Aug 19, 2014 | 12:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Guess my HP - Going to dyno this Saturday
Lock converter, 370whp/355 wtq closed cutout
385/370 open cut.
Linson
Oct 24, 2025 02:00 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
