I swear i searched first
Old Sep 10, 2014 | 07:59 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
Transmission: 5spd manual
I know there is a lot of information in this forum about error codes and what to do, but i couldnt find enough to actually understand what i need to look for
i checked the codes using the tried and true paperclip and got 3 codes
33 MAF sensor signal low, i saw someone mention this and say it doesnt always need to be replaced, but i dont understand how exactly to narrow down the problem
36 MAF burn off, i have a diagnostic for the code i found here but no actual idea where i need to check with the voltimeter to see whats burned out
54 low voltage at fuel pump, the fuel pump was just replaced so what could cause low voltage here?
so i know you all hate hearing it over and over again, but i need to clear the codes in order? and how should i figure out how to do just that?
Old Sep 10, 2014 | 08:45 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: I swear i searched first
Rerun the search in the TPI forum....and look waaaaaaaay back...mid 200o's and before.
Don't get discouraged by "recent info" as many are throwing darts at problem, and hoping it sticks.
Would also suggest going into advanced search, and put in user name Vader, man, he's posted some great stuff on t/sing the TPI over the years.
Old Sep 10, 2014 | 10:03 PM
G-Performance's Avatar
Car: 1992 Z28 25th Anniversary
Transmission: Automatic
Axle/Gears: Stock
Check the fuel pump relay and fuse. Maf gets its power from fuel pump relay I believe.
Old Sep 10, 2014 | 10:05 PM
foxnotgrey's Avatar
Car: 88 Iroc Z
Engine: 350TPI
the fuel pump relay is up by the firewall on the driver side?
Old Sep 10, 2014 | 10:07 PM
Axle/Gears: Stock
Yes. And the fuse is under the dash
Old Sep 10, 2014 | 11:19 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
FP fuse should be up front by your battery, inside the valence.
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
