Idle speed reversed
Old Sep 10, 2014 | 10:06 PM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
Idle speed reversed
I know it sounds strange. I recently picked up an 82 Trans Am. Lg4 auto. Only 50,000 original miles and appears very well kept up. When I start the engine cold, the idle remains low, around 600, and the engine shuts down unless I rev it for a while. However, later when the engine is warm the idle, in park, is high, around 1200. At times, it diesels when I shut it off, from the high idle. Where should I start? I do know the choke does not close when the engine is cold, but, here in Vegas it's 100 degrees, so I don't think that is an issue. Thoughts?
Old Sep 14, 2014 | 07:47 AM
Vader's Avatar
Re: Idle speed reversed
The choke also operates the high idle cam, so it is important to get the choke operating.
Old Sep 15, 2014 | 12:16 AM
Jenkins's Avatar
Car: 1984 Trans Am
Engine: Lg4
Axle/Gears: 3:23
Thanks Vader. My choke now works and the car starts up fine. The check engine light occasionally comes on, usually when the engine is warm and I am stopped. It turns out to be a code 45. The car drives well. One thing I did notice is the MC solenoid does not click when I turn the key. Maybe that is throwing the code.
deracer
Apr 11, 2016 12:04 AM
ezobens
Aug 19, 2015 10:29 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
mizz0313
Aug 12, 2015 06:45 AM
