250 RWHP 383 stroker?
Old Apr 1, 2015 | 09:31 AM
  #51
2005Impalla's Avatar
Car: 86 Z28 T-Top
Engine: Vortec 350
Axle/Gears: I think 3.73 open dif
Re: 250 RWHP 383 stroker?
Also when I was looking at cams for my 383 build before my vortec build comp cams suggested picking a cam I wanted and stepping up about 10* in duration due to the cams predicted RPM range being based off of a 350 CID motor and the 383 needing more duration to stay in the same power band if using the same parts as a 350, heads, intake, ect. The recommendations for the cam are more than likely based on a 350. The 383 will have more vacuum and require less compression than a 350 with the same cam.
Old Apr 1, 2015 | 06:27 PM
  #52
skinny z's Avatar
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
