305 replacement
Old Nov 2, 2014 | 06:31 AM
camarolover18's Avatar
Car: 1986 camaro z28 iroc z
Engine: 305 tpi
Transmission: auto
305 replacement
hi im new here and i just inherited my grandfathers 1986 camaro z28 iroc z 305 tpi it overheated years ago and my aunts boyfriend at the time took the motor apart it never got put back together now i got it and theirs alot mising and i pretty sure its seized. im been looking for a different motor and i was wondering would any 305 block work with tpi im fine with swapping parts and i found a junkyard with a 305 4bc from a berlinetta would it work
Old Nov 2, 2014 | 07:17 AM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: 305 replacement
86 + blocks have a 1 piece rear main seal.
85 and down have a two piece. you can use either or, but you will have to use a different flexplate\flywheel on the 2 piece block because your original one won't bolt on.
87+ TPI blocks were roller cam. I would find one of those. I've also found them in caprice's.
so yes, any 305 block will work. you'll just have to use the proper flexplate and cam for the block you have. other than that, it'll bolt right in.
Old Nov 2, 2014 | 07:24 AM
Engine: 305 tpi
Transmission: auto
Re: 305 replacement
the one i found is in a 1986 berlinetta same year as my car so would the flex plate and cam be the same the berlinetta is a 4bc and i have tpi anything else would i have to change
Old Nov 3, 2014 | 03:59 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 305 replacement
late production 86 engines were the first roller cam 1 piece RMS. if it were me ,I would look for a 87-92 305. you plain do not want a flat tappet cam block.that berli motor is probably not the one to go for.
Old Nov 5, 2014 | 05:11 PM
Engine: 305 tpi
Transmission: auto
Re: 305 replacement
i decided to just rebuild my 305 thats in the car but for the life of me i cant seem to get the exhaust manifold bolts off does anyone know the size of them and any tricks to get them out
Old Nov 5, 2014 | 07:50 PM
Car: 86 IROC
Engine: 5.0 TPI
Re: 305 replacement
pb blaster and a torch, works every time.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
marcusaw
Aug 10, 2015 08:13 AM
