Power steering belt removal.
Old Nov 14, 2014 | 09:40 AM
82z28power's Avatar
So I have an 82 camaro and I'm replacing all the belts. I just can't seem to figure out the one on the power steering pump. I've loosened the bolt the connects to the water pump and the the one on the right side under the ac pump but it won't budge. Can anybody tell me what I'm missing???
Old Nov 14, 2014 | 09:46 AM
ronaldgtp's Avatar
Car: 90 iroc 5.7
Re: Power steering belt removal.
If I remember right there is a bolt behind the pump pulley you have to loosen with a wrench.
Old Nov 14, 2014 | 11:20 AM
82z28power's Avatar
There is one on the top by the ps fill which is the pivit point, one on the left side half way down that bolts into the water pump and one on the right about halfway down that is just attatched to a braket. Am I missing one?
Old Nov 14, 2014 | 11:30 AM
ronaldgtp's Avatar
Car: 90 iroc 5.7
https://www.thirdgen.org/forums/tech...ring-belt.html
Old Nov 14, 2014 | 02:52 PM
82z28power's Avatar
I figured it out. I had to take the nut and washer that was on the water pump off ask it would slide. The washer was blocking the way. Guess thats what happens when the last person that owned the car puts the wrong washer in its place.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
