Looking to Remove my Air Pump
Car: 1991 GTA Trans AM
Engine: 305 TPI V8
Transmission: 4-Speed Automatic (700-R4)
Would anybody know what I need to remove my Air Pump, like pulleys or belts or what have you.
I already have my headers installed, and they don't have the ports for my air pump, nor do I want to keep the pump, and my where I live we don't need smog testing
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Looking to Remove my Air Pump
Basic hand tools will remove the air pump once that is removed u can remove all the air emissions junk and clean up the engine bay alittle bit
Engine: LR4 4.8
If u have a serpentine belt hawks 3rd gen sells a smog pump delete pulley that u can out in place of the air pump or u could change the water pump the a same rotation as the crank and get a belt from 1993+ k series pick up truck and just route ur belt the opposite way so it makes the pump spin the same way as crank
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
If you choose to do so, I also recommend getting the delete pulley. This keeps your belt size the same and you don't need to change anything else. Make sure the ports on the Cat are crimped very well and remove all that tubing coming up. Or, get cats without the AIR tubes. Disconnect and plug the vacuum port on the EGR, but keep the electric switch (mine is on the passenger side by the distributor). The ECM isn't smart enough to know you've removed anything, unless you disconnect the switch, then it will throw a code.
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
So my AIR pump went bad and I removed it. Do I have to remove anything or block off anything like the pipe attached to the pump? I just want to get it running for the time being. I will strip everything off later.
TIA
Geoff
TIA
Geoff
Car: 86 Trans Am WS6
Engine: 383 stroker
plug the piping coming off of the manifolds with a plug. I bought a brass end plug from the plumbing section in home depot for like 30 cents.
Car: 1990 T/A
Engine: 5.0 TPI
Well I pulled the pump, got the longer belt and rerouted it. I fired it up and there are no exhaust leaks. I did not block anything off and it seems to run fine. I am hoping a buddy of mine will bring his coder over this morning so we can deal with the 100mv issue and maybe dial in some tune as well.
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
