Ticking noise
Old Dec 14, 2014 | 07:40 PM
tr4nshum4n's Avatar
Ticking noise
I drive a 1991 5.0L TBI Camaro RS.
I replaced the spark plug wires and set the timing today. I should have done it a long time ago; it runs much better now. It no longer wants to die at traffic lights, and it accelerates much more smoothly.
I also replaced the distributor and spark plugs recently. I used a Cardone distributor, but kept the original. I may rebuild it sometime.
The only problem is this new ticking noise. It's not too loud. The frequency tracks with RPM. It is audible when I'm in park.
I parked it and opened the hood. It seemed to come from the general area of the alternator.
I've never removed the valve covers.
What are some likely causes for a new ticking noise from this area?
Old Dec 17, 2014 | 06:26 PM
tr4nshum4n's Avatar
Re: Ticking noise
I'm still clueless on what's making the engine tick.
I hooked up the vacuum gage today. It read right at 19 inches at idle, didn't move much. The noise is audible in the video.
I think I'm going to try putting in the old distributor and see if that helps.
Old Dec 18, 2014 | 03:00 PM
91 rally sport's Avatar
Car: 85 iroc z, 03 ram 1500
Engine: 305 tpi, 287
Transmission: WC T5, NV3500
Axle/Gears: 3.42, 3.55s
Re: Ticking noise
might be an exhaust leak
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
