Oil pressure gauge maxs out, Engine bogs down
Old Jan 13, 2015 | 03:33 PM
92heritage305rs's Avatar
Car: 1992 Heritage Edition RS
Engine: 305 H.O.
Transmission: 700R4 Built
Axle/Gears: 4:10 Positive Traction
I have a 1992 Camaro with a TBI 305. When the engine is cold if it revs above 2500 rpm the oil pressure gauge will max out way past the 60psi mark until the needle can't go any further. As soon as the pressure rises the engine starts to bog and lose all power until the transmission shifts (700R4). I'm not sure if the pressure rise is just the gauge malfunctioning or not, but I have no clue as to what is going on. Any help or suggestions would be greatly appreciated. Thanks in advance!
Old Jan 13, 2015 | 07:35 PM
Re: Oil pressure gauge maxs out, Engine bogs down
What's going on is, your engine is cold.
This causes 2 things: relatively high oil pressure (because the oil is still basically candle wax) and consequently low oil flow, which in turn means poor lubrication, which in turn again, means the engine is not ready to have any significant load put on it because you'll just tear it up; and, since fuel doesn't evaporate well when it's cold, a lean mixture with occasional large blobs of solid liquid fuel (which doesn't burn) instead of vapor.
Solution is, let your car warm up a bit before driving it. Doesn't have to be "all the way" warm, just, learn from your experience, and don't drive it until the symptoms you asked about, have cleared up.
Then, be glad you live in TN and not somewhere that's actually cold. You'd just have to wait a bit longer.
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
