Hood Clearance
Car: 1986 Camaro Sport Coupe
Engine: 383 Stroker
Transmission: stage 2 2004r
Axle/Gears: 3.55
Hood Clearance
Hi, would my stock 1986 Camaro Sport Coupe hood clear a HSR with the Billet accel Throttle body? it seems a lot bigger that the stock throttle body.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Hood Clearance
it's a fairly common question. Thread Starter
Engine: 383 Stroker
Axle/Gears: 3.55
Re: Hood Clearance
I did research this quite a bit before i asked the question both on here and on google to search within this site. All i found was on firebird hoods and stock throttle bodies. I know how close a stock throttle body on a hsr fits on a gta because my good buddy had one and he had to cut the underhood braces. I believe the camaro has more clearance for the hsr but the accel/lingenfelter billet throttle body sticks out a considerable amount more than a stock throttle body. So i didnt find any useful info by searching and didnt want to spend hours looking and maybe find something useful.
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Re: Hood Clearance
Can someone confirm that the HSR may still rub even after removing the hood bracing? Will it still rub a Camaro and a Firebird or just a Firebird?
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
