Mass Air Flow, Consistantly bad
Old Mar 10, 2015 | 10:02 PM
Phirewire's Avatar
Car: 87 Iroc Z28
Engine: 350tpi
Over the past year, I've replaced the Mass Air Flow unit 3 times. Every time I received a standard code, checked the power and everything just to see the unit is infact bad. Now, this occurs after the car has driven or idled for 30 miles or so. So brand new out of the box it all seems good its not a sudden death. I don't have oil-ed intake or anything like that its all factory, yet it keeps "dieing".
Any guesses why these keep going bad I mean $100 a pop is not fun.
Old Mar 11, 2015 | 06:03 PM
Cosmik Debris's Avatar
Re: Mass Air Flow, Consistantly bad
Is the voltage regulator good? Are there any voltage spikes on your electrical system?
Old Mar 11, 2015 | 06:14 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
now HERES a subject I know something about. are you ,by chance, buying "NEW" ones or are you going down to auto zone and getting "A1 cardone " re man ones?? if you are (and you say $100 .which almost guarantees it) you, my friend , are wasting money. no amount of cheap azz Chinese junk is ever gonna fix the issue. you HAVE to buy a NEW one. I suggest you go to oreilleys and buy a NEW "rich-porter" MAF and be done with it. you also need the burn off relay and the power one too. I have the correct part numbers , should you need them
Old Mar 11, 2015 | 09:06 PM
Phirewire's Avatar
Car: 87 Iroc Z28
Engine: 350tpi
Let me grab all those part numbers, I don't have a O'Reilleys near me. The ones I've been buying are from A1 Car Done from Pep-Boys..
Old Mar 14, 2015 | 11:16 AM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Transmission: 700 R4
Axle/Gears: 2.77
I'm interested in that part number. I haven't had a whole lot of luck with the Autozone replacement. What about a new AC Delco?
Old Mar 14, 2015 | 11:31 AM
Car: 86 IROC
Engine: 5.0 TPI
ok boys, the "rich porter" MAF sensor part number is "MA157". the burn off relay is "R3009" and the MAF power relay is "R671". I get my parts from oreilleys. now these work with the 7165 ECM found on 86-89 firebirds and Camaros with the infamous TPI system. after MUCH money and time wasting, I have found these to be the best deal out there. no need to consider anything else. good luck with your cars
Old Mar 15, 2015 | 11:57 AM
gm muscle's Avatar
Car: '89 Iroc-Z
Engine: 5.7 TPI
Axle/Gears: 2.77
So the stock burn off and MAF power relay will not work witht the Rich Porter MAF?
Old Mar 15, 2015 | 02:33 PM
Car: 86 IROC
Engine: 5.0 TPI
i forgot to mention the relays are BWD brand. and the stock relays will work. but i always change them ,just to be sure that its all proper. also, i crossed the part numbers from the GM numbers , so i know they are correct
Old Mar 15, 2015 | 03:56 PM
Nonwoven29's Avatar
Car: 1986 Iroc z28
Engine: 5.0
Thanks for the need to know info!!
It always sucks tobuy crap. I agree the az sensors of all sorts and types fail shortly after instal. Been there done that with several makes and models.
Old Mar 15, 2015 | 05:02 PM
AC delco ones are good too.
Old Mar 15, 2015 | 08:23 PM
Car: 86 IROC
Engine: 5.0 TPI
no problem, thats what were here for. if you need any further assistance. you know where to come to. before i got wise ,i bought 7 of those "A1 cardone" POS MAFs from auto zone ,the last one didnt even make it out of their parking lot!
Old Mar 16, 2015 | 12:44 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Before you buy another MAF,did you consider checking the MAF Power Relay and the MAF Burn Off Relay??
Old Mar 16, 2015 | 08:17 AM
Car: 86 IROC
Engine: 5.0 TPI
a good idea, it a good thing to just replace them . and at $15 a pop, its not too expensive
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
