rear end troubles
Old Mar 23, 2015 | 07:15 AM
CYNTHIA79's Avatar
Car: 1985 iroc
Engine: 305 tpi
Axle/Gears: 273
rear end troubles
Noticed fluid under rear end. Can't see where the leak is. Refilled with gear oil and now on deceleration it hums. Can someone tell me where this is headed.
Old Mar 23, 2015 | 10:26 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: rear end troubles
Do you have the Limited Slip Differential in it? If you do, did you add the tube of Limited Slip Additive?
Old Mar 23, 2015 | 11:26 AM
CYNTHIA79's Avatar
Car: 1985 iroc
Engine: 305 tpi
Axle/Gears: 273
I just went to the parts store and bought the lube. It said castrol axle limited slip 80w-90. That was the only thing i put in.
Old Mar 23, 2015 | 11:51 AM
gt4373's Avatar
Transmission: 5-Speed Manual
This Is The Additive.
Old Mar 23, 2015 | 12:03 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Dats da stuff. You may have to take some fluid out if you filled it up all the way. Or just jack up one side of the car a little to allow you to add it. No biggie
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
