I removed the stock steering wheel and air bag. How do you turn off the audible error
Old Mar 25, 2015 | 06:31 PM
WalkingBread's Avatar
I recently installed a quick release system. Now I have the awful "key in the ignition sound". How do I bypass it or disconnect it? Also if someone knows why my instrument cluster backlights aren't working I would greatly appreciate that knowledge. I replaced the fuse, switched to led's. I know they aren't faulty because the check engine light works. Thanks for your time!
Old Mar 25, 2015 | 06:58 PM
LsxMatt's Avatar
Car: 86 Sport Coupe
Engine: 5.3 LM7
Axle/Gears: 4th gen 3.42 posi
Re: I removed the stock steering wheel and air bag. How do you turn off the audible e
The speaker for the ignition chime is under the dash on the drivers side, near your right knee. There's a little black flip down box and its a big black rectangle plugged in next to your turn signal and flasher relays. You can just pull it out and the chime will go away.
Old Mar 25, 2015 | 07:45 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
it might help a bit more if you completed your profile . people do not know what car you are asking about . could be a Yugo , Lexus , Crown Vic , Toyota , and the list goes on . not meant as a slam , just a little helpful hint . good luck ...
Old Mar 26, 2015 | 11:40 AM
92 Camaro RS. Being as it is a 3rd gen forum I figured that information would be redundant
Old Mar 26, 2015 | 04:50 PM
UNCLE TOM's Avatar
hang around the forum a while , you will see . BTW firebirds are 3rd gen also . anyway there are many differences between a 1982 & 1992 Camaro , not to mention firebirds .
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
