vortec head swap questions
Old Apr 17, 2015 | 02:40 PM
jdreswick's Avatar
Car: 1986 Trans Am
Engine: 327 .030 over sbc
Transmission: wc t5
Axle/Gears: stock
Hey guys I am doing what you might call a budget build on a 355 and I got some vortec heads for free which was awesome but I sent them to my local machine shop and now they are like new. My question is what thickness head gasket should I go with. In a car craft article were they built a 305 with vortec heads they used 0.015-inch head gaskets. What do you guys think I should go with?
Old Apr 17, 2015 | 02:49 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: vortec head swap questions
Head gasket thickness needed will be based on your block's deck height and your piston's compression height.
The idea is to get around .035" to .045" quench height... Quench height is the space between the top of piston at TDC and the bottom flat quench pad on head.
Stock specs are 9.025" deck height, piston sits .025" in hole.
So you add gasket thickness to how much the piston sits in the hole.. .025 + .015" = .040" quench.
If your block has been 0 decked, then piston is flush with deck at TDC and you would want a .038" or .041" thick gasket
I have used the fel pro 1094 .015" thick head gaskets on many engine builds
Old Apr 17, 2015 | 09:52 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
If you're dealing with a stock shortblock, your deck clearance will be .025"-ish and you definitely should use the Felpro 1094 .015" gaskets.
Old Apr 18, 2015 | 07:45 AM
jdreswick's Avatar
Car: 1986 Trans Am
Transmission: wc t5
Axle/Gears: stock
Thank you for the help guys. From what I understand the block may have been decked slightly when the previous owner had the motor gone through. I will try the ask the guy if he knows but it sounds like the 1094's are a safe bet.
Old Apr 18, 2015 | 07:23 PM
Car: 1988 Camaro
Measure for your self. Then you know for sure and there is no guessing. You can measure how far the piston sits in the hole with a straight edge and a $2 feeler gauge once you have the heads off.
Just rotate the engine to bring piston to top dead center (TDC) as high as it will go. Lay a straight edge across the deck and slide feeler gauges under the straight edge ontop of piston.. Use the go, no go method. Meaning say a .025" gauge slides in tight, but a .026" will not go
Old Apr 19, 2015 | 08:35 AM
jdreswick's Avatar
Car: 1986 Trans Am
Transmission: wc t5
Axle/Gears: stock
sounds easy enough next time I get time to work on the car I will check this. thank you!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
