How many tooth flywheel do I need.
Old Apr 29, 2015 | 09:19 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I have a 5.7 700R4. I'm switching it over to a 5 speed and noticed there's a 153 and 168 (I think) tooth standard flywheel available. Which would I need to avoid starter issues? Mines still installed so I can't check right now. I'd like to start getting orders in for this swap.
Old Apr 29, 2015 | 11:19 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: How many tooth flywheel do I need.
153.. the larger ring gear won't even fit inside the stock T5 bellhousing..
Old Apr 29, 2015 | 02:28 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Neither will the auto starter.
Old Apr 29, 2015 | 02:39 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Really? I have to change the starter too? Can I get away with just changing the pinion?
Old Apr 29, 2015 | 04:15 PM
danryanm's Avatar
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Changing the pinion would be even more work. If you have a factory bell housing, use a 153-tooth flywheel and pick up a starter from any parts house (mine cost a whole $25 and has a lifetime warranty.) If you are using a scattershield, you can use either flywheel, just make sure to get a starter made for it (stagger bolt pattern for the 168-tooth or inline for the 153-tooth.) Also a consideration, not all blocks are drilled to accept both starters. Of course, which clutch kit you get is also dependent upon which flywheel you use and which input shaft your transmission has. Again, no worries here, just look at what you have and match accordingly.
Old Apr 29, 2015 | 06:26 PM
Dyno Don's Avatar
It's the nose of the auto starter that is too big.
You night want to check, sometimes when they get replaced, they give out the standard starter at the auto parts store. (they both work on an auto)
It's just a little round on the end where the bolts are.
Old Apr 29, 2015 | 06:28 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
This is a pure street car. No track so I'm just using the stock T5 bell housing and factory size flywheel and clutch. I guess I'd just get the 305 starter for a manual?
Old Apr 30, 2015 | 07:26 AM
danryanm's Avatar
Engine: 350 4bbl
Correct on the starter. You will need the 153-tooth flywheel. One final question: What did your T5 come out of? If you don't know, then how many splines are on the input shaft and what is its diameter?
Old Apr 30, 2015 | 08:18 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Its from an 88 GTA 305
Old Apr 30, 2015 | 08:52 AM
danryanm's Avatar
Engine: 350 4bbl
In that case, you'll be fine with an off-the-shelf replacement clutch kit.
If you encounter any snags, there are plenty of us who've done the job and are more than willing to help. It is by far the best thing I've ever done to the car; it completely changes its character. You won't regret it.
Old Apr 30, 2015 | 09:14 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Thanks. Been wanting to do this for a long time. Can't imagine what that thing will be like with a 5 speed.
Reid Fleming
Oct 10, 2015 09:56 PM
gord327
Oct 3, 2015 01:25 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
