LB9 fuel system bleed off
Old Jun 15, 2015 | 10:04 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
So one thing I noticed when I checked my fuel pressure is that it bleeds off really fast.. What would cause it to bleed off so fast..... My pressure while idle is 44psi and with it unhooked it was 49-50psi... But would not hold during priming before I start it...
It would take. About or less than 5 seconds to bleed off to 0 I'm not sure why.
Old Jun 16, 2015 | 06:57 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: LB9 fuel system bleed off
Outside of an outright leak , which you would see and smell the escaping fuel , there are three things that cause this .
#1 Leaking injector(s)
#2 leaking fuel pressure regulator
#3 leaking check valve built into the fuel pump
Old Jun 16, 2015 | 07:28 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
"#3 leaking check valve built into the fuel pump"
I second that!
Old Jun 16, 2015 | 09:27 AM
happyhapka's Avatar
OK so either its my inj.. Or fuel pump... Hmmm. OK thank you guys... You all are awsome
Old Jun 16, 2015 | 10:06 AM
happyhapka's Avatar
One more question how long should they hold pressure... How fast is it suppose to bleed off
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
gta90
Sep 15, 2015 04:00 PM
backtothe80s
Sep 5, 2015 12:39 AM
kyleb24
Aug 15, 2015 08:24 AM
