Steel Sleeves
Old Dec 18, 2001 | 09:29 AM
82Trans Man's Avatar
Steel Sleeves
Anybody ever steel sleeve a block is it a good idea. I don't know if I'll be able to salvage anoter 455 but I can sure try if a steel sleeve for a perfomance build is a real bad idea. Never had this problem with 350 chevys if ones bad toss it aside and get a new one. All replies appreciated. Thanks James
Old Dec 18, 2001 | 12:21 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
From what I've heard, it's a pretty reliable repair method. The only drawback is that it's prohibitively expensive, shops around here charge in the neighborhood of $100 per cylinder. For what it's worth, I believe the aluminum LS1 block is sleeved from the factory, so it's probably OK for a performance engine.
3rdgenparts
May 21, 2016 11:50 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
