Bolt size
Old Jun 28, 2015 | 10:44 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Bolt size
I just picked up a complete serpentine belt system. Only problem it didn't come with any of the mounting bolts. I have searched the Internet over and can't find what size they are anywhere. So who can help me out?
Old Jun 28, 2015 | 11:06 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Bolt size
Besides the big aluminum brackets, there's quite a mix of braces, studs, nuts, and bolts with both hex and torx heads. Not sure, but hopefully someone has a documented list of what's required. I tend to think stripping a complete junkyard engine would be easiest.
Old Jun 28, 2015 | 11:11 PM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: Bolt size
I hope so. I just need the ones that mount the system to the block
Old Jun 29, 2015 | 12:20 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Bolt size
Well most of the holes in the block will be 3/8-16 if that helps you any
Old Jun 29, 2015 | 07:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Bolt size
The second link provides a parts list and install guide:
https://www.thirdgen.org/forums/afte...rsion-kit.html
JamesC
Old Jun 29, 2015 | 09:19 AM
Buloushie's Avatar
Car: 1986 Z28 Iroc
Re: Bolt size
Thank you JamesC that was what I was looking for.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
