brand new lifters collapse over night?
Old Jul 24, 2015 | 12:12 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
melling soaked n oil for a week. put them in car .sat overnight .went out this morning to put rest of motor back together. and 9 out of 16 were collapsed!? wtf?
Old Jul 24, 2015 | 06:34 PM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Re: brand new lifters collapse over night?
Soaking in oil wont fill the cavity under the lifter internal piston - it has to be pumped in. What do mean collapsed? How did u test this? U mean u cant move the cup down or its bottomed out? Only on some and not others? '91 formula means roller lifters so u can check them buy hand upside down pushing down on them onto a p-rod and that into a block of wood. Well new lifters the spring that keeps the cup up is pretty stout and can be tough to compress w/o oil inside. My used 125k mi roller lifters with oil still in them wont compress at all by hand.
Sounds more like u cant identify zero lash and have collapsed the cup all the way while adj the preload.
Old Jul 24, 2015 | 11:48 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
they collapse when there isn't any oil pressure and they are holding a valve open, which is what about half of them will be doing at any given time..
Old Jul 25, 2015 | 01:30 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
I had them at zero lash. they were fine when I put them in motor then when I went out to put rest of motor back together 9 of them let go because the rocker arms just slopped around.
Old Jul 25, 2015 | 11:41 AM
cardo0's Avatar
Engine: 350 Gen II
Transmission: A4
That makes even less sense than your first post. Im out'a here!
tommy z-28
Oct 6, 2015 10:58 PM
Stryker412
Sep 7, 2015 09:11 AM
dimented24x7
Sep 6, 2015 03:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
