it's cold, and i have no heat
Old Dec 18, 2001 | 09:21 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
blower works, but the heat only gets to about 75 degrees. max. does this sound like a heater core?
Old Dec 18, 2001 | 10:18 PM
TBIfly's Avatar
I removed my heater core last summer (to lose the weight associated with it...hoses/clamps/core, etc)
Mine didn't work all that well to begin with.
When I removed the dash to repair/install things, some of the foam that is there to help prevent air from bypassing the ducts and heating/cooling your dash was obstructing the duct and (i assume from the heater) had formed a mild plug, not completely but enough to obstruct flow.
Id recommend checking the pressure coming out of the vents when your AC is on, then again with your heater...if there is a significant difference, then you may have an obstruction. Also check the marriage of the hoses to the body at the firewall (2 hoses right next to each other) I too mine out rather than repair it since I live in southern CA. You can look forward to a couple hours removing the underpanels/knee bolster bracket/lowering column and removing the dash, id definitely recommend getting a spotter on this one, i did it alone and it took a good 2 hrs to align the dash again to put a couple bolts in to hold it. Nothing easy about doing the near splits in dickies in a so CA summer alone trying to support a 75 lb dash with a shoe, a telescoping rod, and various other items.
good luck
Old Dec 18, 2001 | 11:00 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Living in Western Canada, I can sympathise
From long experience, here is my advice. If the heater core is gone it will usually leak and drip onto the passenger side floor. If not, it might be getting plugged. But try replacing your radiator cap first. Believe it or not, a leaky rad cap can keep you from getting decent heat from the heater.
If none of that helps, try one step hotter on the thermostat. If there is still no joy, then replace the heater core.
Old Dec 18, 2001 | 11:03 PM
Engine: 305-4v
Another sign that it is the heater core is if the windshield keeps fogging up inside. That is due to the leaking coolant evaporating through the vents and condensing on the inside of the windshield.
Old Dec 19, 2001 | 02:28 AM
JPrevost's Avatar
Car: 91 Red Sled
Another tip is to scrap the heater switch that is controled by the climate controls. The heater switch only lets coolant go into the heatercore when you have the heat or vent switched on. The old school way is to just bypass and rip out all that crappy heaterswitch stuff and just let the coolant run through the heatercore. It works for me and it really cleaned up the engine bay. If you want to know how to do it go to my website, I have a simple tech article.
Old Dec 19, 2001 | 10:13 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
If you have a 160 thermostat you can easily have this problem on a cold day.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
