91 rs 3.1 fuel pump
Old Aug 6, 2015 | 04:02 PM
Newguy91rs's Avatar
91 rs 3.1 fuel pump
Just got my camaro and was told fuel pump was bad...what kind of other problems can check before I go through that work. Glad to be apart of the third gen family.any advice will help...thanks!!!
Old Aug 7, 2015 | 09:46 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Re: 91 rs 3.1 fuel pump
Well if it shows usual symptoms of fuel pump failure then it is more than likely the fault. Just check fuel pressure when you crank it, if its good gas and no leaks with low pressure, yank the pump. There are other technical ways to diagnose the pump, usually pretty simple though. By checking fuel pressure you negate needing to check the ignition system for now
Old Aug 7, 2015 | 09:51 PM
Newguy91rs's Avatar
Thanks a bunch... Thinking about going inline pump as well any thoughts?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
