Fuel level rheostat/pot replacement part number
Old Sep 12, 2015 | 02:57 PM
Springster's Avatar
Car: 1986 Camaro Sport
Engine: 2.8L
Axle/Gears: Stock
1986 2.8 MPFI
Anyone know the part number for the fuel level rheostat? It's held on by 2 screws and mounted on 2 springs. I would think that just that part is replaceable instead of having to replace the whole sending unit...
There is a part number on the plastic mount but searching for that yielded nothing.
Or, it looks like just the float/rheostat could be replaced.
Thanks!
Pat
25004739 14
Old Sep 13, 2015 | 12:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel level rheostat/pot replacement part number
I've never known them to be available separately. However, man GM cars use the same rheostat. So hit up a JY and grab one for another vehicle and install onto your sending unit.
RBob.
Old Sep 13, 2015 | 01:38 PM
Springster's Avatar
Engine: 2.8L
Axle/Gears: Stock
Thanks for the info. I was actually able to fix the bad connection with a strip of copper but I had to buy a whole new sending unit. Part of it broke that I couldn't fix.
With a Bosch turbine pump and new sending unit I should be set for a while.
1992 Trans Am
May 10, 2023 07:19 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
