Passenger side accessories bolt hole size on AFR heads help
Old Sep 23, 2015 | 08:12 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
So I used the bolts from the stock cast iron heads for accessories bracket on the driver side with my AFR heads and they fit great but the passenger side AFR heads bolt holes or smaller or have a diff thread pitch. I can get the bolt to start maybe one thread befor it stops....what bolt size do the AFR heads take on the passenger side?
Old Sep 23, 2015 | 08:25 PM
Damon's Avatar
Re: Passenger side accessories bolt hole size on AFR heads help
Shouldn't be the case. They're all 3/8-16. Front, back, left, right... doesn't matter.
Old Sep 23, 2015 | 10:35 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The threads might not be cut right. Might want to run a bottom tap thru there and see if they clean up.
Old Sep 23, 2015 | 11:32 PM
Night rider327's Avatar
Car: 1988 Camaro
All SBC gen 1 heads, stock, aftermarket, afr, brodix, dart, etc.... Uses ONLY 3/8-16 for acc. bolt holes in ends of heads and for exhaust manifold/header bolt holes.
Old Sep 28, 2015 | 01:45 AM
Car: 92 1500p\u 2wd
Ran a tap through them and there good now....thanks guys
Old Sep 28, 2015 | 05:50 PM
UltRoadWarrior9's Avatar
Car: 1986 IROC Z-28
Engine: 383 Gen I SBC 11:1
Transmission: Rebuilt TH700R4 for 500+HP
Axle/Gears: 4th Gen 10 bolt Eaton Truetrac 3.23
That's nice to know! I'm looking at AFR heads too. Thanks for posting!
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
LittleFranks
Aug 20, 2015 03:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
