Transmission wont shift
Old Oct 10, 2015 | 09:28 PM
Tas's Avatar
Tas
Trying to get ready to sell the 1989 Firebird formula after 20 years. Transmission has been having issues. I filled it with fluid but it's not shifting. What could it be? It's a tbi 305.
Old Oct 11, 2015 | 08:15 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Transmission wont shift
You're positive it's filled correctly? (With it running and warmed up, switched through all the gears and then checked fluid level?) did you mess with the detent cable at all? Is it properly set if you did? If all that checks out then she might of bit the dust
Old Oct 11, 2015 | 01:03 PM
Tas's Avatar
Tas
I haven't messed with any cables. I checked it warm and in park. I did not manually shift through all the gears. I can try that next. Thanks Dust where?
89Pontiac
Apr 5, 2016 06:04 PM
firechiken47
Oct 10, 2015 06:16 PM
::Andy::
Oct 8, 2015 11:29 AM
Tat2shag
Oct 7, 2015 11:34 PM
zimmstoy
Oct 4, 2015 08:23 PM
