PAC 1218 springs enough to xfi280 roller cam?
Old Oct 21, 2015 | 01:13 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Valve weights int.=110g exh.=95g max power ~6400rpm.What do you think,is it ok,or does it need more spring pressure??
Old Oct 21, 2015 | 01:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: PAC 1218 springs enough to xfi280 roller cam?
It may be enough, but i'd rather use the 1219's
Old Oct 21, 2015 | 04:44 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I would'nt use a single spring on that cam profile , they will probably break.
Mine did, almost lost the motor.
[The PAC single valve springs will use your factory seats, seals, retainers, and locks! We recommend stepping up to a dual valve spring kit if you plan to run more than .600" lift and/or a valve larger than 2.08" diameter.]
Good advice
Old Oct 21, 2015 | 08:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Pac isnt the same as the old comp beehives
LiquidBlue
Nov 9, 2015 10:24 PM
rode1951
Oct 21, 2015 12:58 PM
mcweens
Oct 20, 2015 11:07 PM
dwisti
Oct 18, 2015 04:12 PM
