Hard start will not stay running mass air flow problem
Old Oct 21, 2015 | 08:38 PM
Barilow's Avatar
Car: 88 iroc
1988 camaro will not run longer then a couple seconds with mass airflow sensor plugged in. Unplugged the car runs fine I have replaced the mass airflow sensor and I'm having the same problem.
Only engine modifications are headers and exhaust. 350 tpi
Old Oct 22, 2015 | 03:29 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Re: Hard start will not stay running mass air flow problem
Have you checked your TPS sensor adjustment ?
Also MAF power or MAF burn off relay could be bad
Old Oct 24, 2015 | 02:33 PM
Barilow's Avatar
Car: 88 iroc
Just changed the power relay and cleaned the burn relay stays running but not well 1000 rpm to just under 500 over and over again. Could it be a vacuum issue? Check engine code is 33 and 34 if I read the code right
tommy z-28
Oct 6, 2015 10:58 PM
85 Jimmy
Sep 30, 2015 07:56 AM
FormulasOnly
Sep 10, 2015 09:07 PM
Jk_Under
Sep 8, 2015 08:13 AM
