1989 pontiac trans am tpi 350 Idles fine but has No power.
Old Nov 11, 2015 | 02:06 PM
Dalton1989's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: TPI 350
Hello yall, im having a problem that has officaly stumped me and im looking for some help/advise.
Problem: Car has no power what so ever. Wide open In a half mile i can maybe push 35-40mph depending on the wind. No joke. The throttle repsonce in netural or park is very slow and takes for ever to build rpms.
Parts so far: Fuel filter, Fuel pressure regulator, all 8 injectors are Bosch 4 hole remaned. Plugs, wires, cap, rotor. Intake plenum gasket set new air filter. Coil and Ignition module will be this weekend. Ecm was replaced by the previous owner from a scrap yard, i still have the orginal one. not sure why it was replaced. Engine and Transmssion were rebuilt less than 20k ago, transmission shifts strong havent been able to go fast enough for 4th gear yet tho. been in 1st-3rd Its not hardly driveable unless you have 20 miles of flat land witch i dont.
The car sat in a feild for 2 years before i got it. Its my girls car she got 4 years ago and it ran just like this when they got it. She Drove it like this for a year before the tires wore off of it. (small own Usa)
Extra info: Fuel pressure is 40psi Key on eng off. 39-45psi running and 45psi with regulator unplugged. I have changed the timing several times starting at 0* to now im at 6* advanced. Idles 1000-1100 in park and 650 in gear. In gear it runs kinda rough but still will move the car, hasnt stalled on me yet. There are no vacuum leaks ive sprayed starter fluid all around the intake while running. The check engine light works but goes off soon as the car is started. Tried flash codes but it only shows 12.
I disconnect the battery every night to prevent parasitic draw.(not saying it has one just not willing to risk it right now)
Im looking for some advice/help on where to turn to next before i just throw more money at it with no avail. It has a off brand Red coil on it currently. Not msd
Will work on the car toight to start testing sensors with a mulitmeter.
Old Nov 11, 2015 | 03:14 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 1989 pontiac trans am tpi 350 Idles fine but has No power.
Bad MAF bad/dirty will be my 1st guess. Unplug it and see if it runs better.
Old Nov 11, 2015 | 03:33 PM
Dalton1989's Avatar
Engine: TPI 350
Ok ill be home in 2 hours that will be the first thing i try. Thanks for you input.
Old Nov 11, 2015 | 07:09 PM
TTOP350's Avatar
But it could be any number of things..
Old Nov 11, 2015 | 08:17 PM
Dalton1989's Avatar
Engine: TPI 350
Ok so I unplugged the Maf.
car hesitated to start and took a min to warm up, but now it has regained some of the power/ throttle response back. Couldn't test drive due to coming home to a flat tire that leaks down just as fast as I air it up. Will fix tomorrow.
With it running better without the maf suggest that the sensor is bad ??
Old Nov 11, 2015 | 09:04 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
It means that the maf is probably bad. You might also want to check the ESC module which is behind the relays on the drivers side firewall.
Also check the VIN, if it is a swap car and someone just swapped the block from a 305 to a 350 and not the electronics, it could cause funny issues.
for a 350, it should be 1G2FW**8*K*******
if that 8 is an F, then you have a 305 from the factory, and you might want to start checking part numbers on the prom in the ECM, ESC module, and knock sensor
Old Nov 12, 2015 | 06:31 AM
Dalton1989's Avatar
Engine: TPI 350
Checked the vin it is an original 350 car. I guess I'm going to bite the bullet and replace the maf even tho it wouldn't store a code. As far as the esc what exactly should I check power, connection, ? Thanks for the info
Old Nov 12, 2015 | 07:48 AM
alex722607's Avatar
I don't think anyone makes a quality MAF for TPI cars anymore. I keep seeing that anyone who buys one is returning it within a month cause it failed. As far as the ESC module, I can't remember off the top of my head. I will post a link to the online version of the 88 manual, it has the same diagnostic trouble tree as 89 cars. It should help you figure it out
Old Nov 12, 2015 | 07:51 AM
alex722607's Avatar
http://depositfiles.com/files/ty1vrpu5x
Regular download should work fine
Old Nov 12, 2015 | 08:10 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Have you checked for a clogged cat(if it's still on)or clogged muffler? Sitting in a field for 2 years it's no telling what might of crawled up in there. Wife's TA years ago, cat went to pieces, no power. Changed cat out, still no power. All the pieces went to the muffler and clogged it up. Replaced muffler, ran like a champ.
Old Nov 12, 2015 | 08:12 AM
Dalton1989's Avatar
Engine: TPI 350
Well crap that was gonna be my next question was who makes a good one I see prices of $150 and up. Thanks for the manual I will download today after work and post back what I find. Thanks for the help
Old Nov 12, 2015 | 12:42 PM
Dalton1989's Avatar
Engine: TPI 350
I have thought about it but the exhaust sounds fine. If the cat is clogged won't it glow cherry red when running ? And I can unbolt the muffler when I get off work.
Old Nov 17, 2015 | 09:22 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
+1 on the clogged exhaust idea . i would remove the Y pipe from ith manifolds /headers and see what happens
Old Nov 17, 2015 | 10:25 AM
TTOP350's Avatar
Its easier to remove a manifold checkvalve and do a PSI check on the exhaust while running.
Old Nov 27, 2015 | 08:30 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Check the exhaust, prolly clogged cat....
Old Jan 18, 2016 | 07:34 PM
Dalton1989's Avatar
Engine: TPI 350
Thank you everyone for the responses/replys, sorry its been so long, I've been so busy and haven't had any time. So today I unbolted the exhaust from both headers and started it up. Made a world of difference, (plus sounds so much better.) Throttle response has improved greatly and acceleration has Greatly improved. (now it will easily power break and light the tires up no problems)
However it still doesn't have that seat of the pants pull in first and second gear that its supposed to have. Also I didn't run it more than 5mins and drive more than a mile if that matters at all
Any tips or tricks to get this car on point ? thankyou again everyone for you help.
Old Jan 19, 2016 | 10:22 AM
thtanner's Avatar
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Richporter MA157 are good MAF sensors. Different design (single screen).
Old Jan 19, 2016 | 11:10 AM
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
Originally Posted by Dalton1989
Engine and Transmssion were rebuilt less than 20k ago,.
don't know how many cars I looked at that say this. and not a single one with receipts. LIES.
now that you got it running decent I would pull plugs and do a comp. check and look at plugs. might help
