PCV Valve Vacuum Hose question
Old Dec 21, 2015 | 10:37 PM
tecboy's Avatar
Engine: 350 - 305 801 Heads
Axle/Gears: Stock
Hey Guys, Yesterday I was checking over the engine while running and I noticed the vacuum hose on the PCV valve was sucking closed. It was a little soft I admit but I am wondering if that is the reason, or if I should be looking for something else.
I noticed that the car is running extra rich and can smell it. I was reading and some were saying that may be the reason its running rich.
Any help would be appreciated.
tec
1985 Camaro Z28
305 Small Block
Edelbrock High Rise
Holley 750 Double Pump Carb
Headers - 3 inch pipe to flowmasters
Old Dec 22, 2015 | 03:04 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: PCV Valve Vacuum Hose question
No, the reason it's running rich is cause you have a massive 750 cfm double pumper carb on a tiny 305 engine.
You will need to jet that carb way down and do a lot of tuning to the whole carb to get it to run right on a 305.
Replace your soft PVC hose and go from there. I always use rubber fuel hose for my PVC and power brake vac hoses.
Old Dec 22, 2015 | 06:54 AM
tecboy's Avatar
Axle/Gears: Stock
Wow! Ok thanks for that information! I bought the car like it is, so I will need to rethink that then. Car runs real good but man the smell will kill ya.
Thanks again!
Old Dec 22, 2015 | 08:28 AM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
You can buy PCV specific hose at your major auto parts store, i.e. Autozone, O'Reilly, etc... I was having issue with my '85 Trans Am and replaced the soft and spongy hose. The hose has to be able to withstand the heat from the intake manifold and whatever else it is laying on. Otherwise, at least in my case, there is a vacuum leak.
Old Dec 22, 2015 | 09:16 AM
tecboy's Avatar
Axle/Gears: Stock
Thanks gearhead!
Makes sense!
tec
69GTOby
Jul 19, 2017 12:33 AM
NiG
Nov 13, 2015 05:43 AM
Ron U.S.M.C.
Nov 12, 2015 06:01 AM
74SpiT
Nov 9, 2015 03:30 PM
dale3in98
Camaros Wanted
Oct 26, 2015 09:54 PM
