1991 RS 305: how to adjust fuel/air mixture?
Old Jan 23, 2016 | 06:11 PM
'91CamaroRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
The car is running very rich. I've done a full throttle body rebuild,and put new injectors in,and there's been no improvement on it running rich. I always thought that it was done by the computer automatically. Is it done like that,or some other way?
Old Jan 23, 2016 | 06:29 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: 1991 RS 305: how to adjust fuel/air mixture?
Yes, air/fuel is controlled by the computer.
Is your check engine light on? Have you checked for any stored codes?
A bad O2 sensor is a common cause for a fuel injected car to run rich.
A bad fuel pressure regulator can also be an issue.
I'll have to defer to the more knowledgeable for other culprits.
Old Jan 23, 2016 | 07:32 PM
Car: 1991 Camaro RS
Engine: 305 TBI
The fuel pressure regulator is on the throttle body correct? If so,I replaced the diaphragm for it during the rebuild.
I can't remember if there's a recent code or not. In the past I had an IAT code,but I think I solved that by plugging the harness into it. Where's the O2 sensor located?
Old Jan 24, 2016 | 08:31 AM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
O2 sensors are on the exhaust manifolds/headers depending on your setup. Quick and pretty cheap to replace.
Old Jan 24, 2016 | 09:12 AM
You don't "adjust" the mixture, except with a tune.
I'd suggest just replacing the O2 sensor (driver's side exh manifold) and the coolant temp sensor (front of intake, 1 yellow & 1 black wire). They're both CHEEEEEEEEEP and EEEEEEEEEEEEEEEEEEZY. While just randomly replacing parts for no reason isn't always "the best" way to deal with such things, sometimes it is; it's more expense and/or more trouble to handle the situation any other way.
Old Jan 24, 2016 | 10:39 AM
Car: 1991 Camaro RS
Engine: 305 TBI
Ok thanks
ryan thomas
Jan 24, 2016 05:05 PM
'91CamaroRS
Jan 23, 2016 01:28 PM
dcd2236
Jan 21, 2016 08:42 AM
rickyzZ28
Wheels and Tires
Jan 19, 2016 10:00 PM
86_firebirdTA
Jan 17, 2016 01:45 PM
