Is fuel check valve part of the fuel pump?
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
I was told my fuel pump on my 1991 Camaro RS 305 was "going bad." I find that to be odd because I always thought fuel pumps either worked or didn't work at all. The only indication of a bad fuel pump is that when the car sits for more than 30 minutes it takes 2-3 seconds of cranking to get it to fire up. That's telling me the check valve is bad.
I'm taking the car in to get a sending unit put in,and I'll probably just go ahead and get a new fuel pump along with it. I just wanna know if the check valve ISN'T part of the fuel pump;then I'll know that this other guy is talking out of his ***.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Is fuel check valve part of the fuel pump?
Check valve is part of pump. It's a fairly big job to change the sending unit, and no extra work to change the pump while you're in there so change it.
It's not that a pump either works or doesn't, it's an electric motor that wears with use so it degrades slowly.
Car: 1991 Camaro RS
Engine: 305 TBI
I'll have the shop do it all. I don't have the tools and certainly not the space to do it myself unforntanatley
Car: check
Engine: check
Transmission: check
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
TKO500
Interior Parts Wanted
Mar 15, 2016 11:25 PM
B4C5.7
Mar 6, 2016 05:23 PM
B4C5.7
22
Jan 24, 2016 11:40 AM
