Where do I pull the fuse to shut off fuel pump on 91' Camaro
Old Dec 22, 2001 | 01:34 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'm trying to find the fuse so that I can relive the fuel pressure and change the filter but I can't locate the fuse for the pump. I looked at the fuse box but none of them are labeled as such.
Old Dec 22, 2001 | 02:05 PM
Joshua Leslie's Avatar
I never needed to relieve the pressure on my TBI, I thought about it.
I had no problems, no gas came squirting out or anything, just the normal amout for when changing it.
Old Dec 22, 2001 | 03:36 PM
Enkil's Avatar
I *think* it's the fuse sitting next to the battery attached to the fender. (Hopefully, it's a small black plastic box and on my car it snapped off. :-/ )
Old Dec 22, 2001 | 04:46 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, it is a fuse next to the battery.
Old Dec 22, 2001 | 05:35 PM
BlackBird305's Avatar
to relieve pressure in the fuel system just undo your gas gap and disonect the fuel pump relay...the relay is located in the back of the car...go under the rear end housing and start looking up kind of where the back seats are...there's a weather-pack connector there and it just un-plugs...sorry my directions aren't too clear, long day at work and having trouble explaining where it is...its kinda one of those things u hafta see....good luck
Old Dec 24, 2001 | 03:21 AM
TBIfly's Avatar
when i changed my fuel filter, i didn't pull a fuse. just took off the cap and crawled beneath the car in the rear on the driver's side and took the old filter off, about 1 cup is what came out. thats what it felt like all over my shoulder, ear and arm....yup, about a cup
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
justin57
Aug 20, 2015 07:05 PM
