Starter
Old Feb 8, 2016 | 04:16 PM
sgp0511's Avatar
Car: 1988 Firebird
Starter
So lately I've noticed I had a hot start issue, 305 carb on 88 firebird. What happened was starter would rapidly click if I tried to restart when operating temp. If I kept trying to start for a few mins it would run my battery down then I would have to let it cool down and then get a jump. So I replaced the starter, had battery checked 3 times to verify good battery. Car starts nice and strong, but after getting to operating temp solenoid may occasionally click a few times then car would turn over slowly. So I thought maybe a ground or battery cable issue. I put thicker gauge wire from + to starter. I cleaned grounds to block, ensured wires and connections were clean and tight. Seems to be working strong on a cold morning start. If I turn car off and on a few times in a row, by 3rd start solenoid clicks then starter turns slowly. I checked battery voltage right after that and it was 12.7 or something. Did a load test it passed and checked volts while car running and its 14 volts running. While cranking volts drop to 11. Starting to think it's not a hot start issue, as I performed car on off test while motor cold. After 3rd start motor still cold I can even touch manifolds, I still get solenoid click. And this is on the new starter. I don't know why I still get the occasional solenoid click and slow turnover.
kaupca
Jan 18, 2016 05:46 PM
89 formula TPI
Jan 18, 2016 03:13 PM
86CamaroDan
Jan 13, 2016 09:16 AM
keeneth73
Carburetors
Jan 12, 2016 05:45 PM
84tr
Jan 10, 2016 04:34 PM
