92 Engine Shutting off while driving
Old Feb 20, 2016 | 02:01 PM
crystalweig's Avatar
Car: 1992 Camaro RS
I've had my 92 camaro rs for 14 years and with regular maintenance I've never had a issue. Two days ago while going about 40 mph she just shut down. All the electronics still worked just nothing from the engine. I coasted to a side road popped the hood and everything still looked in place. She started right back up. She has done this every day since and I can't drive her now because I feel like it's getting dangerous. I replace the plugs, wires, cap, and router. Still the same problem. Fuel pump primes up and my idle is fine it just seems like something is just shutting the engine down. Has anyone come across this issue or have any suggestions on what to target next? V8 305 w/ 115,000 miles
Old Feb 20, 2016 | 03:46 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 92 Engine Shutting off while driving
Have your ignition control module ICM checked at autostore if it already hasn't been replaced.
Old Feb 20, 2016 | 07:03 PM
B_Dubya's Avatar
Engine: 305 5.0 TBI
Transmission: 700-R4
tbi or tpi?
Old Feb 20, 2016 | 09:05 PM
Mark Stanley's Avatar
Car: 83 Z-28
Engine: 305 crossfire "Renegade setup"
Someone had this issue I knew before and it had something to do with a fuel issue, think it was like it thought it needed fuel when it was already taking in the correct amount and flooded itself causing it to kill out.
Old Feb 21, 2016 | 07:07 PM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
Fuel Filter? If it's definitely spark start with ICM under the distributor cap first.... If that isn't it, start looking at the ECM under the passenger side dash.
Old Feb 23, 2016 | 06:38 PM
Car: 1992 Camaro RS
Originally Posted by B_Dubya
tbi or tpi?
Tbi
Old Feb 23, 2016 | 06:40 PM
Car: 1992 Camaro RS
Couldn't find a place to check it, but I think that's where I'm going to start. I've read some other threads that suggest that as well.
Old Feb 23, 2016 | 08:31 PM
antares57's Avatar
Took both of mine to Autozone. One was bad, the other not.
Curtisyz54
Jun 29, 2011 10:32 PM
Baalz159
Feb 27, 2011 11:35 AM
