New motor time!!!
Old Apr 27, 2016 | 02:54 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
New motor time!!!
Parted out the 355 over the last while and that with my tax return I've decided it's new motor time!!!! This is what I'm thinking
-427 sbc stroker 12:1 CR
-Dart SHP block 4.125 bore 350 mains
-Mahle forged pistons
-Scat 4.00" stroke crank
-Scat 6.0" H beam rods
-AFR eliminator 235cc heads 70cc
-single plane efi intake(undecided) opinions???
-comp cams 4 pattern cam grind#299QS10
Using the above cam with 12:1 SCR the dynamic CR works out to be about 8.1:1. It'll be like a 60/40 street/strip car. I'd like to spin to around 7200 rpm. What kind of power do think this setup will provide??? Any and all opinions are welcome guys!!
Old Apr 27, 2016 | 07:35 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: New motor time!!!
With those cubes spinning to 7200, if you don't make at least 600 at the crank, you did something wrong.
That's a ridiculous price on that cam -- $687...yikes!
I wouldn't be running hydraulic lifters at those revs. Street solids with positive pin oiling would be a safer bet and make more power.
Whether HR or SR, I'd go here for a custom cam that will cost less and make more power:
elliottsportworks.com
