Horsepower RPM Peak: Opinions
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Re: Horsepower RPM Peak: Opinions
Well this turned out to be a really good thread for those building a 350" for the street and drag racing. Greg had some really good results/info to share. It shows that while simulation software is helpful and trends changes it is only as good as the programmer and his experience. Once running and racing the combo will tell u the story and hopefully where to go.
Good luck Skinney and let us know how it works. Thx for sharing everyone.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Be sure to check PTV clearance if you decide to experiment with 8 deg advance.
Absolutely. It's something I'll check in that position whether I decide to go that advanced or not. I've got a timing chain/cover set-up that'll let me change the cam timing without dropping the pan so to know the clearances will be handy if I want make a change mid-season.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Read the cam advance article by Vizard on speedtalk. He goes into what most sbc seem to like for advance. If heads have good low lift flow then it wont want advance
I will check that out for sure. Thanks.
EDIT: Found it.
http://speedtalk.com/forum/viewtopic...it=cam+advance
fastfbody
May 1, 2016 02:24 PM
