IAT question
Old Jun 1, 2016 | 02:01 PM
David Fite's Avatar
Car: 1986 IROC-Z
IAT question
My car doesn't have an IAT sensor in the bottom of my open element cleaner. Never had one since I bought the car. my question is where does the wire go so I can try and find it (maybe it's zip tied up some where?)? Once it leaves the air cleaner I have no idea where that wire should go/connect.
Old Jun 1, 2016 | 05:52 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: IAT question
Does your service engine soon light come on? If not the sensor is probably plugged in and hanging around or tied up somewhere. The little white two connector plug is on wiring about a foot long that come from the big wire loom going along the passenger side valve cover in the area between the dist, air cleaner and the map sensor. If you can't find it I can get you a picture
Henry
Bowtieman1970
Aug 17, 2016 02:50 AM
Knight Prowl
16
Apr 12, 2016 06:56 AM
Chough262
Apr 10, 2016 01:20 PM
RedLeader289
South East Region
Apr 7, 2016 06:55 AM
FormulasOnly
Mar 19, 2016 05:54 PM
