Need Help
Old Jun 8, 2016 | 10:02 AM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Need Help
I need some advice just to clear my brain.
I got a lt4 hot cam in my 1988 gta 305 5 speed
I just put in in on weekend...I took both heads off
im porting and polishing my lb9 heads they were awefull....
so much restriction raised casting marks they were the worst heads I ever did.
I still have one more head to do....
Here is my question.
I got new valve springs....
seat pressure is 110lbs open 325
cams in the 480-520 lift range max lift of .550
now I talked with them and they said it should be fine
I just want to make sure...
cam is 218/228 at .050 .492 .492 lift... with 1.5 rockers...
I got 1.6 aluminum roller rockers and I want to use them... so .525 lift on both...
will these springs be on with the 1.6 alum .525?
Old Jun 8, 2016 | 10:04 AM
Re: Need Help
Probably not.
What springs? How are they set up?
Old Jun 8, 2016 | 10:08 AM
bensbaby's Avatar
Engine: 383 built
Re: Need Help
I havnt even installed them yet
I was just gonna install them like stock springs
