Hi guys
I am fighting with my 89 L98 Trans Am. Few days ago I have changed valve seals. As you know after that I have to set the valve lash. I did it (with 1/4 turn after zero lash) Car runs but have slow throttle response and low power overall. So yesterday I decided to go another 1/4 turn. Engine runs better and has more power. But...after 30miles when engine gets full warm temperature problem appeared. When I stood on red light Engine shaking strong (500-3000rpm) sometimes dies and sometimes get high idle (2000rpm for example)
I've parked the car and returned when cold. Start the engine and drive 15miles without any problems. Could this caused by too tight valves?
regards
regards
TTOP350
close
- Join DateOct 2001
- LocationIl
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car1989-92 FORMULA350 305 92 Hawkclone
- Engine4++,350 & 305 CIs
- Transmission700R4 4800 vig 18th700R4 t56 ZF6 T5
- Axle/Gears3.70 9"ford alum chunk,dana44,9bolt
- Liked:1,166 Times in 759 Posts
Do you have stock injs ?
Quote:
yes, stock. replaced 7mths ago.Originally Posted by TTOP350
Do you have stock injs ? sofakingdom
close
- Join DateSep 2005
- iTrader Feedback Score(1)
- CarYes
- EngineUsually
- TransmissionSometimes
- Axle/GearsBehind me somewhere
- Liked:2,502 Times in 1,909 Posts
Sounds like you have valves that are too tight.
Adjust them with the engine running.
No substitutes.
No substitutes.
