fuel pressure question
Old Jul 9, 2016 | 09:51 PM
racereese's Avatar
Car: 1987 irocz28
Engine: 305 tpi
Transmission: t5 5 speed
Axle/Gears: GU4 3.08 g80
Ok having a little trouble. Pick up a fuel pressure tester. When i start engine it goes right up to 40 psi exactly. When i gove it gas it drops a couple of pounds but returns to 40psi. Engi e struggles whn giving it full throttle like getting on freeway or climbing hill. I got codes 44 and 45. Is this a pump issue or regulatir possible injector issue?
Old Jul 10, 2016 | 10:58 AM
Vader's Avatar
Re: fuel pressure question
If the pump and FPR are operating properly the rail pressure should RISE when the throttle is opened, not fall. Is the inline filter clean?
Old Jul 10, 2016 | 03:56 PM
racereese's Avatar
Car: 1987 irocz28
Engine: 305 tpi
Yes i changed the filter before test i was hoping that was the problem. Runs decent just cant take full throttle starts to studdder.
Old Jul 11, 2016 | 04:25 PM
Abubaca's Avatar
That sure sounds like a fuel pressure regulator. ....I mean vacuum will cause the reg to raise the pressure. It's not a real complex part. I can't see how vacuum from acceleration could NOT increase pressure, provided the FPR is working properly.
Old Jul 17, 2016 | 12:10 PM
racereese's Avatar
Car: 1987 irocz28
Engine: 305 tpi
Ok to add progresss on problem. They are both bad. Idle would get riugh at cruising speed 30-45 range. Replaced fpr took for test drive 30-45 smoothest ride ever. But i hooked up the gauge and wired to my hood scoop so i can watch while driving. At high speed pressure would not build. At 60mph i would give it full throttle car would studder and not pick up speed quickly and gauge would hit 43psu then go crazy bouncing between 38-45psi quickly and it seemed in sync with the studdering.
Question can i out an inli e pump with old pump still in tank but disconnected? I will be going to a friends house using his lift so can drop tank. I just dont want to buy a new in tank fuels pump as i have no future plabs for one. I will be using a inline pump. Just wondering for now if i can just put the inlibe on and go. Will be parking it in next couple of months if i get a truck for work and will begin stripping down for rebuild. But need to get to work to get down payment for truck. Just want to limit the money going into it since im not going to be usung any of the stock fuel parts in future going for ls swap.
Old Jul 17, 2016 | 01:26 PM
racereese's Avatar
Car: 1987 irocz28
Engine: 305 tpi
Also with vacuum line off fpr fuel pressure only rises to 45psi. And stock pumps at orielly say they have max of 51psi.
instaldave
Apr 7, 2016 06:14 AM
Dskeezy16
Apr 4, 2016 08:01 PM
scarr001
Mar 25, 2016 10:50 AM
Z28DJP1987
Aftermarket Product Review
Aug 2, 2001 03:01 PM
sweetgn
Nov 14, 2000 07:14 AM
