Can Anyone ID These 2 Sensors / Modules? (no part #)
Car: 1990 Firebird
I'm going through my spare parts and ran across these 2 sensors/modules. (I have a '90 V6 3.1 Firebird.) Can someone help ID these? Just want to make sure they're trash before I throw them out. Thanks.
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Can Anyone ID These 2 Sensors / Modules? (no part #)
First one looks like an ESC module. Second is definitely ignition control module.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
The first one is an electronic spark module module that sits near the relays above the brake booster.
The second is an ignition module that lives in an external coil distributor.
Edit: Never mind....
Car: check
Engine: check
Transmission: check
The flat module is a knock filter, the hot stamp shows it as BLH. Which is an early 4-pole unit. Used on 5.0l & 5.7l carb'd engines. Being an early 4-pole unit they are very discriminating. Although you can't use it on the '90 Firebird.
The other unit with the 369 ink stamped is an ignition control module (ICM). That unit is used in the performance TPI small cap distributors. You can use it in the '90 Firebird as it uses the same type of ICM. But again a desirable ICM module.
RBob.
codbottle
Nov 24, 2011 05:38 PM
BthomasM
Jun 28, 2009 07:52 PM
