What is this part?
Old Sep 7, 2016 | 07:00 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
What is this part?
What is this pump? Can I drive on this for a day or two until I get this part or don't even start the car back up? Needa fast fix as I must drive this car until Nov. 1.
88 IROC Z28 305...120,000 Miles
Old Sep 7, 2016 | 07:40 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: What is this part?
Smog pump pulley. Should turn smoothly with the belt. Any wobbling could possibly be loose bolts( 10mm ), but play with noise usually means pump or bearing failure. Noise is mostly nuisance and unless really loose can last for a bit until you replace it. Lots of play can result in increased belt wear though
Old Sep 7, 2016 | 08:39 PM
Axle/Gears: Posi
Frozen...it's not moving with a loud noise...whine
Old Sep 7, 2016 | 09:11 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If the pulley doesn't turn then the pump is shot and needs replacing. The loud screechy noise is the belt slipping on the pulley ( should be making the pulley really hot) Belt will break soon leaving you stranded. Unless you can route the belt around it somehow
Old Sep 7, 2016 | 09:28 PM
Axle/Gears: Posi
Nope...gonna park the car. Should I go new or used part.
Old Sep 7, 2016 | 11:11 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
New is not that expensive, used is just asking for it. Pretty easy to change too
project89
Jun 13, 2008 09:48 PM
Stekman
Mar 15, 2005 11:09 AM
breathment
Aug 9, 2002 11:51 PM
breathment
Mar 26, 2002 12:20 AM
un4givin89
Mar 15, 2002 11:43 AM
